Vixen LVW 42
Started by David Simons, 05/10/2007 04:50PM
Posted 05/10/2007 04:50PM Opening Post
Hi Folks,
I just received my Vixen LVW42 from the Vixen America closeout sale. I have been looking for the ultimate rich field eyepiece for my 8" f6 scope, and this ep may be it.
I tried it last night in somewhat foggy skies, so I know my eye pupil was no where near 7mm, but the view was very comfortable, with just a hint of softness near the edges of the field. Very nice even with my glasses on. If my calculations are right, I was getting:
Mag=1200/42 ~29X
The specs on this ep list a 72 degree FOV, so
True FOV = 72 degrees /29 = 2.48 degrees
I was using a correct image diagonal, and it felt like I was looking through an 8" finder scope.
However the 72 degree spec on this ep deviates from the rest of the series at 65 degrees. Has anybody made any measurements to verify Vixens claims on this 72 degree?
David Simons's attachment for post 37033
David Simons
Posted 05/10/2007 05:58PM #1
I have made FOV measurements on several EPs and have found that most, especially low to moderate priced 2" EPs do not yield the true FOV in my scope that the EP FOV should give. Tele Vues tend to be spot on (Plossls, 24 WF and 12 T4 Nagler). Hyperions show a wider field than the EP FOV would give, however, there may be some distortion. Haven't checked that out.
My methods have been to use a steel tape at +400 feet and star fields in Cygnus and Hyades. They compare very favorably. Star field measurement is difficult if you do not have tracking, especially with short FLs and steel tape measurements require a calm day.
I Yam What I Yam!
