Ghost of Cassiopeia
What good is a really long FL eyepiece?
Started by Lee_S, 10/17/2007 01:24PM
Posted 10/17/2007 01:24PM Opening Post
I've seen a lot of really long focal length 2" eyepieces (53mm to 80mm) on a nonsponsor site. That would give about 15x on my 8" Dob. Is magnification that low worth having for seeking DSOs?
[SIZE="Small"]------------
[/SIZE]
Posted 10/17/2007 02:45PM #1
That mag would give you a 13+mm exit pupil - far to large for anyone's eyes (7mm is exceptional) to take in.
Posted 10/17/2007 04:01PM #2
Those focal lengths in eyepieces are useful especially on long f.l. refractors and slow reflectors, IMO.
James Adams
Posted 10/17/2007 04:01PM #3
For a fast Dob it makes no sense, but for long refractors it's a lot of sense.
For instance, take a fictional 80mm 50deg afov EP:
Scope:
80mm f/15 Vixen = 2.19 TFOV -- 15x -- 5.53mm Exit Pupil
5" F/12 D&G = 1.73 TFOV -- 19x -- 6.67mm Exit Pupil
6" F/12 D&G = 1.44 TFOV -- 23x -- 6.67mm Exit Pupil
6" F/15 D&G = 1.15 TFOV -- 29x -- 5.33mm Exit Pupil
8" F/12 D&G = 1.08 TFOV -- 30x -- 6.67mm Exit Pupil
So basically, for any f/12 or longer telescope, the exit pupul of these long FL EPs makes them quite usable and what is needed to get some larger TFOVs.
Posted 10/18/2007 04:50AM #4
I think the other flunkies got the answers right so I will take some time to try to confuse you... grin
Take that 80mm eyepiece, in an F/6 telescope the exit pupil will be 13.3mm in diameter. Well, that's a bit of a problem because even if you are a young buck and eye still opens nice and wide to 7mm, there is a whole lot of light not making in to your hairy eyeball where it can do some good.
So, what you have done with 80mm eyepiece is reduced the effective aperture of you scope from an 8 incher down to something close to 4 inches and while you were doing that, you have increased the relative size of the central obstruction by about a factor of 2...
One more flunky joins the thread...
Posted 10/18/2007 12:22PM #5
Lee,
Depending on your focal ratio of your dob you would see your secondary with an eyepiece of that length. I can remember sliping in a 55mm Plossl and seeing mine.
Jay
Posted 10/18/2007 06:20PM #6
Not really. Those eyepieces are meant for "slower" scopes.
In fast scopes, it's better to use eyepieces with a larger apparent field of view that show the same true field, so that you can look at the same piece of sky under higher magnification. Given that a 40mm Paragon or Pentax XW and Nagler 31T5 have a field stop close to the maximum reachable in a 2" eyepiece, there's little point in anything longer if the exit pupil will be too large to be optimal anyway.
While you *can* use exit pupils larger than your fully dilated eye pupil, there is no point in it other than to show more sky - extended objects are smaller but the surface brightness is the same (or smaller), and point objects become dimmer.
Posted 10/18/2007 09:39PM #7
Thanks for all the feedback. I don't think I want to see my secondary through the eyepiece and my refractors don't have 2-inch focusers. So, I think I'll pass on those for now.
[/SIZE]
