Had a chance to try my WO UWA 2" 28mm. EP this week at the Oregon Star Party...5K' Elv. transparent viewing, my scope the first evening was my 9.25" SCT. well Col. and dead-on with my "go-to" CG5... the views through the moderately powered (84x) set up were wonderful tack sharp and to the edge of the 82ยบ field.. the EP is almost as big/bulky & heavy as the 31Nag. My only issue (and shared with others in our group) was the "black-out" problem. might be inlarge to the f.10 of my Celestron. Once I located a sweet spot for my eye position (pressed firmly) against the eyeguard I could get the full Space window effect. The eyeguard end does feature a rotating type adjustment, if you will... similar to the slide type on the Naglers.. I found that turned all the way in worked best for me.. "proof is in the Puddin" though, everyone is different.. My Nag. 22mm. t-4 exibits no black-out whatsoever for me, where as some of my friends have that problem with it.. I think you will enjoy the views this EP offers when handled correctly.. John M
