Folks, Most nights I struggle to align my permanently scope in a reasonable amount of time and usually settle for "good enough". Last week, I noticed a laser alignment tool on a tripod at work. After taking a closer look, I saw that each leg had a built in bubble level with adjusting thumb screws. If that setup was good enough for a laser alignment, I figured why not try it on my C11 mount.
After a trip to Home Depot buying 3 cheap $2 bubble levels I placed them on my mount near each bolt. I was shocked to find the level way out! The first thing I did was to remove the mostly deteriorated rubber wafers under the top plate and the above the underneath bolt (these should never have been installed anyway). Originally, I leveled the top plate using a carpenters level then just attached the mount/scope but never checked the final level. While I could not get a wrench on the the 1 1/4" bolts which were mostly buried under all the metal, I was able to hit a screwdriver with a hammer to adjust the above bolts. Once exactly leveled, the underneath bolts were tightened and the level was still perfect.
I am hoping that this precise leveling will make polar alignment a snap. Of course I will need a clear night to check it which has been rare here in CT. Clear skies
Regards,
Steve
Regards,
Steve
