Skylight observatory-Info. Anyone done one?
Started by Melnmarn, 10/23/2004 09:05PM
Posted 10/23/2004 09:05PM Opening Post
I want to put in a skylight in one of my bedrooms, and turn it into an observatory. Anyone done this? I looked on the 'net and have only found vague info on this. I know what needs to be done for the pier, but I need info on the skylight. IE: Where does one find one that will open all the way, not just to vent, or do you need to modify a vented one? I live in rainy country (Washington state) so it needs to be waterproof when closed, fairly easy to open, (without climbing onto the roof). This will be on a second story, on the south side of my house, as the best skies I have are to the south of me.
Any info would be helpful, links would be nice as well...
Thanks in advance... smile
Wayne
[COLOR="Blue"]Wayne[/COLOR] 8O
_________________________________________________________
Never stop looking up!!
Takahashi TAO-130on a Losmandy G-11 Gemini 4
Williams Optics Zenithstar 105 APO on a G-8 Gemini 4 (Field setup)
ST2000XM with CFW10/L-R-G-B-Ha-SII-OIII filters
Home Built backyard Observatory
Understanding Wife.. 8)
Posted 10/24/2004 01:55AM #1
Wayne, I have installed several operable skylights but have never seen one that was designed to open all the way. Thinking back how most are designed I would say that most can have the stops removed/modified to open further. There are also several manufacturers out there that build custom lights and glass enclosures. If you can afford it you could have one built. The biggest problem I see is that your roof is more than likely constructed with trusses that are 2ft on center and you would only end up with a finished opening 20" or so wide which seems to me would greatly limit your viewing.
---George
