Ruben Tommasi
Andromeda Galaxy (M31)
Split rolloff roof for observatory?
Started by schnitz, 05/27/2004 02:27PM
Posted 05/27/2004 02:27PM Opening Post
At this point, my future observatory is still in the idea and planning stage. I have a location for the observatory identified and have been lurking on various forums trying to see what works and what dosen't and what problems arise with various configurations.
I live on a knoll on a small mountain and have relatively good skies. The major problem is wind. In this regard, a dome would no doubt be superior. However, I find the relative ease of constructing a rolloff roof to be an overriding consideration. But, why not have the best of both worlds? If I split the rolloff roof in two sections so as to be able to move each half independently, it would seem that some of the advantages of a dome could be obtained. The slit between the roof halves could be positioned to allow viewing and yet be narrow enough to give some protection from wind.
Can anyone comment on the concept of a split rolloff roof? Better yet, has anyone done this and can they refer me to pictures?
Thanks
Russ Schnitzer
Posted 05/31/2004 09:15PM | Edited 05/31/2004 09:38PM #1
Hi Russ
Here's my analysis.
1. Roll-off roof is easiest and cheapest to make, but equipment is exposed to the wind and cold. Your idea of a split roof sounds excellent, and Rick, I really like the idea of the internal gutter to catch the drips.
2. A dome provides protection from wind, dew and cold, but is difficult and/or expensive to make. Making the slit watertight is no mean task.
So why not combine them!!
I'm thinking roll-off roof with a very light weight dome inside!! The dome would be made of ribs covered with tent cloth - very light and easy to move. The slit would be permanently open so construction would be a breeze. It would provide protection from the wind, dew and cold. On good calm nights the tent cloth could be pulled off the ribs, and the ribs folded down to give an unobstructed view of the sky.
Alternatively, it could look something like the clam shell dome. When the roll-off roof is opened the clam could be erected if required ... remember that it has a permanently open slit.
Posted 06/03/2004 02:20AM #2
I plan something similar. The starting point is a corrugated steel cylindrical building. Rig it to split both ways , and rotate.Then you can have the advantage of shelter, or wide open space for dual instruments or quick ventillation. My main concern would be rotational wind forces which must be overcome by the rotation mechanism.Sealing the join will be tricky, but a spring loaded pull down joint cap could work. Works fine for a straight join,(I used an upside down plastic gutter with no problems) but must expand radially here.
E.Cairns
Posted 06/03/2004 05:34PM #3
Thanks everyone for your suggestions.
I will incorporate the suggestion to essentially plan for leaks at the roof joint and install some sort of gutter to redirect the drips. There will be roof holddowns. Paint will be selected for its temperature control qualities.
The idea of a lightweight dome within the split roll-off roof structure is novel but seems redundant if the split roof concept works out like I think it will. On the other hand, using a lightweight dome within a standard roll-off roof structure has some merit because of the increased protection from wind and stray light. But, I think I'll let somebody else test the idea out.
A split dome is not appealing because it has all the difficulties of dome fabrication and increased weather sealing difficulties. If I remember correctly, the solar towers at Mt. Wilson use this concept.
Thanks again,
Russ Schnitzer
Posted 08/19/2004 03:19AM #4
Have a look here: http://www.alpineastro.com/observatory/index.htm
-Gary
