John Greenlee
Before and after
6.3 Reducer for Mk66
Started by davel, 01/24/2003 03:14PM
Posted 01/24/2003 03:14PM Opening Post
Hi,
Has anyone had any luck using a focal reducer on the f12 M66? Trying to get a wider field.
Dave
Posted 02/04/2003 04:59PM #1
I used a Takahashi FS78 reducer. It worked perfect for an ST7 chip. Field was flat..
I attatched it using a small ring that comes with the Intes reducer that threaded into the Tak reducer turning it to SCT threads.
http://www.markles.com/outbox/tony/other/st7intes/
All these were using the Tak reducer. I was at around 1350mm I believe at f9. I cant remember the focal length of the 6". I know you was looking for 6.3 reducer, I cant answer that one. I had an Intes reducer, but The field looked much better with the Tak reducer,although the reduction was only 25% with the Tak.
Tony.
Posted 02/04/2003 11:34PM #2
I have never tried my Celestron F10 to F6.3 reducer on my MK-66. The next clear night I'll give it a try with a 27 Panoptic and report back. The math works out to F7.6 and should drop the power of the 27 Pan from 68x to 43x.
Clear skies!
http://pages.pathwaynet.com/~mhansen/astro/
Mark Hansen
http://public.fotki.com/mhansen/
Posted 02/11/2003 04:27AM #3
Finally clear skies here in Western Michigan so I tried my Celestron 6.3 reducer on the MK-66. I could not get a 32mm plossl or a 27 Panoptic to reach focus using the Intes SCT 2" diagonal. The scope just barely ran out of focus travel. I removed the SCT diagonal and tried again this time using the 27 Pan directly in a Televue adapter threaded on the back. It did reach focus and the views were sharp/correct to the edge. I observed M42 and the double cluster to confirm functionality. I did not have an 1 1/4 diagonal with me, but believe that would reach focus with 1 1/4 eyepieces using the 6.3 reducer.
Mark Hansen
