james carter
North American Nebula NGC7000
Question about MN66 focuser
Started by cdculbertson, 04/15/2004 02:53PM
Posted 04/15/2004 02:53PM Opening Post
OK, I finally took the plunge and decided to replace the Russian Crayford on my MN66 with a Clement focuser. One of the reasons I went with the Clement was that it offers a wider focusing range than other focusers, and my eyepieces focus from way in (UO orthos) to way out. The Clement should accomodate all of these nicely. The other reason is that Don now carries an adapter that fits directly into the base for the stock focuser and is held in by the setscrews on the base...which leads to my question:
What kind of screws *are* those little screws?? I have tried shining a light into the recessed holes, but I apparently need a new eyeglass prescription, for I can't see what the heck they are. I stuck an allen wrench in there but, since I didn't find a hex hole, I am assuming that they are not hex screws. So, slotted or phillips head?
Thanks for any help!
Doug
Midway, FL
Posted 04/16/2004 01:10PM #1
I have an MN 56 with the same focuser. I seem to remember tightening those with a very small hex wrench (or at least thinking about it). I will try to check that and get back to you.
Posted 04/16/2004 02:07PM #2
Call Mike at ITE - they do replacements of focusers all the time. He will be able to tell you.
Posted 04/17/2004 01:53AM #3
I recently replaced the stock focuser on my MK67 with a Clement. (Smartest thing I ever did.) Mine is held on with 3 hex screws. I just miked the wrench and it's 0.08" across the flat sides. I can only assume that yours is the same.
Garry Buck
