From the
ATWB Customer Gallery
HorseHead and Flame
C8 Remounting
Started by leen3lpj, 08/29/2017 06:07AM
Posted 08/29/2017 06:07AM Opening Post
I have an older fork mounted C8. I would like to purchase a Losmandy equatorial or similar setup. Can I change my C8 mount scope to an equatorial mount or do I have to get another scope?
Lee
Posted 08/31/2017 12:55AM | Edited 08/31/2017 12:56AM #1
Hi Lee,
Sure you can change the fork mounted C8 to equatorial, which fork mount do you have? In general you should be able to remove the tube/ota/scope body from the fork arms and then attach an appropriate mounting rail either a losmandy or vixen and then attach the scope to the matching equatorial mount saddle.
Tell me which fork mount you have and I should be able to guide you on disassembly (a photo would be helpful).
Regards,
Greg
Posted 08/31/2017 03:15AM #2
Lee
Parallax makes rings specifically at 8.9" for exactly this purpose on a C8. A set of those along with a dovetail will address the issue nicely. They pop up used from time to time on AM for around $100 a set. New they are a bit pricey....$220
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Statham GA
Posted 10/12/2017 08:24PM | Edited 10/12/2017 08:33PM #3
Lee
Lee,
I remounted my C8 Powerstar many years ago. I did the same with an Ultima C11.
There are C8 D-plates, Model DC8, available from Losmandy that will match the saddle on their GEQ mounts. These mount to the bottom of the OTA (and top of the OTA should you desire to piggy back a guide scope and/or camera). The OTA already has threaded holes in the proper locations on both sides of the OTA.
If you go this route just be careful to verify you receive the correct mounting hardware, i.e. the proper diameter, thread pitch, and most importantly the length of the mounting screws. There have been a few sad stories where the screws were too long and impacted the optics.
To de-fork the C8 you remove the fork arms from the drive base first, then remove each arm from the OTA. When you examine the top and bottom of the OTA you will find screws plugging the threaded holes where the Losmandy DC8 attaches. You remove these screws and use the Losmandy supplied hardware to mount the DC8. Again, VERIFY that the length of the mounting hardware isn't too long!
-Gary
    AP178 F/9, C11, C8, ED80, TV-85, TV-102, SW120ED, 6"Cave F/8, Solarmax 40, DM-6,
    Losmandy Titan 50 GEQ, G11, AP800, Denk BVs, 7x50 Fujinons, 10x50 Nikons, 15x70 Astrophysics,
   16x70 Fujinons, 22x100 Oberwerks, Sim Picheloup CPT, Canon 40D, 60Da, Vixen Polarie, SXV-H9,
   DMK 41AU02, DBK 21AU618, Shelyak Lhires Lite Spectroscope
    Vice President, City Lights Astronomical Society for Students (CLASS)
    President, The Texas Astronomical Society of Dallas (TAS)
    Select Member/Volunteer, 3RF Comanche Springs Astronomy Campus
    Operations Team Lead, Texas Star Party 2013 (TSP)
    NASA-JPL Solar System Ambassador (SSA)
