CGEM Computerized Mount : Looking for User Experie
Started by astrodad1954, 01/13/2009 05:39PM
Posted 01/13/2009 05:39PM Opening Post
This looks like the beast I want...any one had a look at this item yet, the CGEM Computerized Mount? Am contemplating with the C9.25 OTA for visual and possibly imaging purposes. Thoughts appreciated.
astrodad1954's attachment for post 45184
Posted 01/13/2009 07:04PM #1
Have not heard enough on them in actual use, but I have read a little. Some concern over PE and unguided images and one fellow received a DOA mount. Noise levels are higher than a CGE and said to be a little noisy, but not too bad.
However, it is not a lot of money and seems like a nice mount.
Posted 01/13/2009 07:35PM #2
If you're doing 100% visual, then almost any mount will do for a C9.25.
If you want to kill your interest in astrophotography quickly, then these kinds of mounts will do that for you. Get a Losmandy G11 for the C9.25, not because of its weight, rather because a 9" telescope is a very formidable instrument when it comes to imaging. In order to steer it to 1 arc second levels, which this scope is capable of, you will need a precision mounting. On the other hand, if you will be imaging with an 80mm short refractor, then just about any cheap mount will do.
Rolando
Posted 01/14/2009 12:45PM #3
This mount should be sufficient for the 9.25. I say "should be" because this is a new piece of gear. The similar Atlas is being used quite successfully for imaging with mounts in this size/weight range.
Uncle Rod
Time on your hands?
