2" focuser for Orion 3.6" OA
Started by scottw, 05/27/2010 06:55PM
Posted 05/27/2010 06:55PM Opening Post
Can one just put a 2" focuser on an Orion 3.6" OA scope and therefore be able to use a 2" 55mm eyepiece to it's advange? Or does one have to move everything? Or should I just forget it?
With nothing much to do
Scott
Posted 06/02/2010 09:36PM | Edited 06/02/2010 09:38PM #1
As long as focuser height & range is satisfactory, you can simply exchange the focuser. However, it is doubtful the full Field Of View of a 2" diameter long focal length eyepiece can be realized; IOW likely there will be vignetting at the field edge due to diagonal size & placement. Use of a 1.25" 28mm or 32mm focal length eyepiece is probably the widest True Field Of View you can expect without vignetting. Or a 24mm SWA type 1.25" eyepiece will yield the same True FOV via a wider Apparent FOV & greater magnification.
