Ghost of Cassiopeia
NEW:Orion 190mm Mak Newt Astrograph
Started by drachal, 07/22/2008 10:33PM
Posted 07/22/2008 10:33PM Opening Post
Don't know if this is newsworthy or not, but I thought I'd pass it on.
http://www.telescope.com/control/product/~category_id=optical_tube/~pcategory=telescopes/~product_id=09972
Darian R.
Posted 07/22/2008 11:14PM | Edited 07/22/2008 11:14PM #1
Interesting product. I like the price and size. The surfaces, including the mirror, are almost certainly spherical (at least that would be the goal), and at f/5.3 they would not be too steep. This scope would not, as claimed, have a flat field (it would have a radius of about 1 meter). I also think adding Astrograph to the name is pushing the marketing envelope in a less than genuine way.
I wonder if the quality of the scope is good . . .
Posted 07/23/2008 12:05AM | Edited 07/23/2008 12:05AM #2
I would like to hear from someone that buys this scope. It has some real possibilities for photography and visual use. The price is pretty good and the materials sound good. Orion has usually got a pretty good set of optics from my experience with their mirrors. 20 lbs is not too bad either, most mounts could handle it and a camera with a guide scope.
smile
Posted 07/23/2008 12:34AM #3
Something I noticed:
- It has a 2.28inch Secondary for a 31% CO. That's just about SCT territory. Most Newt-Maks are down under 20%.
- It seems to have a tall focuser or at least one with an extension. I guess that's to make it into an "astro-graph" but it must contribute to the large size of the CO.
Posted 07/23/2008 08:01AM | Edited 07/23/2008 08:12AM #4
According to product specs, the mirror is spherical, it has a Pyrex Primary, 5 baffles for high contrast, a Schott Glass Meniscus Lens, and an Included focuser extension which allows for visual use.
They list the highest useful power as only 200x.
Posted 07/23/2008 12:12PM #5
Well you get what you pay for. However, if Orion can pull it off, the package could be very effective...if they can pull it off. I noticed that they are taking "pre-orders". I may just pop for one to check it out.
True, the glass is readily available in good quality. It all comes down to how well it's put together optically & mechanically.
Even though the surfaces are all spherical, they have to be very high quality spherical surfaces. That means not only low PTV & RMS numbers but smoooooothess as well, which, in my experience, is more important, at least for high power visual work, once you get past ~ 1/5 PTV for the system. Then you need high quality coatings
The other thing that gives me pause is what I see as a trend of Synta type suppliers to "ship & fix". That is to get the product out in a hurry and fix the quality & design issues later. Orion can screen that sort of thing but if the reject rate is high, well, it may never see the light of day...I mean night.
Clever though in that they don't take the Intes brand products (MN76 & MN86) on directly except for price.
We shall see.
Jeff
"Don't sweat the petty things and don't pet the sweaty things" 8O
Posted 07/24/2008 03:08AM #6
Some observations regarding this scope:
1) When I first saw the photo, I assumed it was made by Intes-Micro. The design of the front cell looks exactly like the perforated cover used by I-M to allow airflow into the tube.
2) I own an f/4 MNT and at that focal ratio it's barely possible to reach up into the tube to adjust the secondary for collimation. At f/5.3 reaching the secondary would be almost impossible. Collimation of this scope is going to be "interesting" unless the secondary rotation is spot-on.
3) Focal ratios less than f/6 have lots of higher-order spherical aberration unless a surface is made aspherical to minimize it. An all spherical design (implied at this price) would not perform very well compared to other scopes with better figured optics.
Jim McSheehy
Posted 07/24/2008 07:15PM | Edited 07/24/2008 07:16PM #7
I ran some experiments on a scope of similar design and here are my results:
1. The diffraction limited field should be at least .6 degrees (full moon).
2. The distance between the meniscus and the primary is not critical.
3. Centralization of the primary vs the meniscus must be held within 2mm (.078").
4. Both curves on the meniscus must be held within .2mm (.008")of the design specification.
5. The meniscus tilt must be held within .2 degrees.
I think these tolerances can be accomplished with modern CNC machines and optical equipment. IMO quality control will be the final issue. I'm looking forward to the first review by a fellow Amarter. If anyone can think of any other constraints I would be glad to run them.
Keith
klawson's attachment for post 123780
Scopejunkie
USAF Vet
