Nexstar 8SE
Started by valta, 05/19/2009 08:07PM
Posted 05/19/2009 08:07PM Opening Post
This scope does not readily accept 2" diagonal and eyepieces.
How can I improve its deep-sky, wide-field performance over stock?
Posted 05/19/2009 08:20PM #1
Walter: Two ways:
A focal reducer like the Celestron F/6.3. This reduces the effective focal length to around 1300mm. This will allow you to use your 1.25 inch eyepieces and get TFoVs up to about 1.2 degrees. I have one I rarely use that I could loan you...
Or you can buy a 2 inch visual back and 2 inch diagonal or a 2 inch diagonal designed to fit an SCT. Then you can use 2 inch eyepieces.
If you try to use both the focal reducer and a 2 inch eyepiece, Vignetting will become an issue...
Jon Isaacs
Posted 05/21/2009 04:33AM | Edited 05/21/2009 04:39AM #2
This past weekend I spent some hours in the virgo cluster with an 8" out under dark sky, down a two track out in a meadow on public land. An 8" f/5 newt on an altaz mount. Most of the time at 90x or more with, 65 degree eps and Uranometria. I was able to pretty much just skip using my lowest power eps because of having detailed charting. I know that may not be a wide field answer for you, but detailed charting plus a portable scope really works well on deep sky. The Nexstar 8's that I have seen are pretty darn nice... and portable.
