Remounting a Primary Mirror
Started by Jud, 09/11/2008 12:33PM
Posted 09/11/2008 12:33PM Opening Post
When I first received my 12" dob, the mirror was adhered to the cell by what seemed to be 2-sided tape. I reattached the mirror after cleaning in a similar manner. Now, my mirror will come back home after refiguring. Does anyone have other recommendations concerning how I may attach the mirror to the cell. It is a 9-point cell with floating 3-point triangles. One of the problems also is positioning the mirror while attaching the cell.
It appears that laying the mirror on its face is the most accurate method of positioning the cell points. Suggestions relating to this activity is also needed.
Jud
I Yam What I Yam!
Posted 09/11/2008 02:09PM #1
Bob Royce, rfroyce.com has some interesting and inexpensive suggestions for mounting dob mirrors using silicone. That's what I do, and it has been very successful for me.
Jud
Posted 09/11/2008 05:29PM #2
If there are no clips for retaining the mirror in the cell, the RTV would be the better choice. You can space it from the pads or just put the mirror directly on the pads with a dollop of RTV, then move it if needed to get it perfectly centered. Your your finger tips to feel the distance from the triangle to the edge and then use a ruler to fix the distance equally by measuring the triangle to the edge. let it cure overnight, 24 hours is better.
