Jay Messeroff
Lunar & Solar Transits
XT10g focuser mod for imaging or binoviewer
Started by jlegere, 01/07/2011 02:10PM
Posted 01/07/2011 02:10PM Opening Post
been contemplating this one for a while now and would like to run the idea across you all.
The xt10 doesn't like my camera or binoviewer. the focal plane is to short. I seem to be about 1/2 inch from reaching focus when I rack it in all the way with my camera attached normally with a camera adapter. I cannot reach focus with a binoviewer installed either. now if I strip off the adapter and the 2" mount ring on the focuser tube so that I can push the cameras mount face flush with the focusers face. I am just about focused.
So, I was thinking that orion just might have made the diameter of the ota just a bit to big so that folks will buy their imaging ota's out of frustration.
The plan is to cut out an opening in the ota so that I can recess the focuser a bit. make a mount face that is actually inside the diameter of the tube.
any thoughts?
Posted 01/07/2011 03:33PM #1
I believe you should be able to achieve focus if you find a way to move you primary mirror a bit closer... maybe a better idea than to fiddle-faddle with your tube & focuser assembly... (which would be more intrusive on your optical path) - food for thought... 8)
Posted 01/08/2011 09:07AM #2
Jeffery:
One of the disadvantages of the Newtonian design is that there is the limited focuser travel. A long travel focuser intrudes into the light path and also requires a larger secondary mirror. Neither of these is desirable.
A Newtonian will be setup for either photography or visual but not both at the same time. The older Newtonians sometimes had two sets of bolt holes for the mirror cell, a forward set for photography, a rearward set for visual. People with truss Dobs who want to use a binoviewer often have two sets of poles.
I have not seen how this scope is built but I would not recommend recessing the focuser, that would be a can of worms and is likely to end up with the drawtube intruding into the light path. One possibility is a Low Profile focuser but these are expensive and have limited travel. The affordable GSO low profile has a design flaw so the bearing rocks easily.
When I have needed to move the mirror forward, I have done one of two things. With a sonotube dob and a standard mirror cell like a University Optics or Kenneth Novak, I have simply moved it forward and drilled new holes. This is probably not possible with the design of the Orion.
A second option is to move the primary mirror forward by replacing the springs and adjustment bolts in the primary mirror cell with longer ones. A good commercial hardware store should have what you need. I am big on keeping things stock so I can put it back like it was. Cutting is a last ditch choice and not to be taken lightly.
If I were in your shoes, I would replace the bolts and springs and be done with it.
