A shorter diagonal?
Started by RobertHowe, 06/13/2009 10:13PM
Posted 06/13/2009 10:13PM Opening Post
Hi ladies and gents,
Preparing to photograph an eclipse at sea, I am trying several combinations of telescopes and cameras. I have a lovely fast refractor that I would like to use for wide field imaging, but the camera only comes into focus if used straight thru with an extender; a 2 inch diagonal is too long by a very slight amount.
For the sake of stability I will have the mount as low as I can; focusing straight through will be difficult even with a solar filter, as I will likely be dazzled by a chance glance of sunlight. Is there any way to shorten the light path of a 2 inch star diagonal? Does anyone sell a shorter 2 inch diagonal?
Cheers
Robert Howe
RobertHowe's attachment for post 47175
Robert Howe
Wilbraham MA
TeleVue 85 f/7 // Astro-Physics Traveler 105 f/6 // Astro-Physics 130 f/8.35
Coronado 60 DS
"Scopes, Brains and Wisdom--but no Beauty"
Posted 06/14/2009 12:51AM #1
How about a shorter focuser? Also, I am not sure it can be adapted, but I thought the dedicated FSQ diagonal was a very short optical path.
Good luck
Kevin
Posted 06/14/2009 05:44AM | Edited 06/14/2009 05:45AM #2
A question rather than answer-- Do prism diagonals sometimes have shorter optical paths than mirror diagonals, because of the refractive effect of the glass? Thought I read that somewhere, but maybe incorrect, or perhaps not significant enough effect to give you your few millimeters. Someone here likely knows.
Posted 06/15/2009 03:35PM #3
Cheers
Robert Howe
Hi Robert:
Baader's T-2 diagonal is very short and there are tons of camera connection options. The prism version of this diagnal comes with Baader Mark V binoviewers specifically for its short path length. There is also a mirror version. The T-2 prism has less than 2" sized aperture though, and I suppose it might vignette, depending on your camera.
http://www.buytelescopes.com/product.aspx?p_id=5738&store_id=&did=#
Jim
