Collimation Issues with Refractors
Started by Barry Simon, 10/11/2004 05:19PM
Posted 10/11/2004 05:19PM | Edited 10/11/2004 09:40PM Opening Post
While refractors are often assumed to be perfectly collimated systems, this is often not the case. I use a Cheshire collimating eyepiece to check collimation and I collimate my own scopes where possible. A Unitron refractor, Brandon apos too, as well as several other refractors have one way or another to easily align the optics at the optics end so that the light cone is centered about the tube inner diameter as it runs straight down the tube. The Unitron (70's and later) and Brandon refractors have spring loaded cells that allow the inner cell holding the optics to be pivoted in relation to the outer cell which is bolted to the telescope tube. Aligning the light cone essentially means that all that need be done at the focuser end (assuming the focus body is build true) is to assure that the focuser is seated on the tube end and that the tube end is cut square or perfectly perpendicular to the tube length.
So then the problem with a scope like my Orion ED 100, the ED 80 or the Orion ST120 and a variety of other scopes is that failing the built in ability to align the primary optics, really good collimation is quite difficult. An adjustment of the focuser end of the tube assembly cannot really be used to collimate a scope perfectly unless the primary optics are in a cell that is in perfect alignment with the tube and the problem is only at the focuser end. The reason being that the light cone of misaligned optics will not line up with the center of the tube and adjusting the focuser cannot rectify this as the optical axis of the focuser and the optical axis of the optics can only at best be adjusted so that the optical path and the focuser line of sight be parallel to one another. This parallel condition is not the same as collimation. However the closer the two are to being both parallel and coincident (parallel offset), the better. This was a problem inherent in long focal length large refractors of the 19th century as telescope tubes generally could not be made as true and as straight as today. Additionally their sheer weight coupled with long length caused some sag. This is why those tubes had to have considerable reinforcement; basically to prevent sag that would greatly affect collimation. So unless you 1) offset the focuser, and then 2)bring the focuser's optical axis in alignment with the optical light cone there is no way to really collimate a scope well from the focuser end if the optical end is the real problem.
I feel that you can improve collimation somewhat, but without the ability to easily collimate from the optics end too, it cannot really be done well in any scope that does not give one this ability. You could shim the objective in it's cell, but this would be a slow process. If well machined, the optics end should be ok, but if the threads for cell attachment are not cut square to the tube, we are both literally and figuratively "screwed". One of the first things to check would be to verify that the cell is not cross-threaded onto the tube.
The light pattern visualized and photographed in my ED 100 did show some misalignment. The cell was not cross-threaded onto the tube. Adjustment of the original focuser did improve the collimation pattern as seen thru the Cheshire collimating tool, but not perfectly. Short of shimming the objective in the cell to center the light cone convergence point at the exact center of the inner diameter at the other end of the tube, there is no way other than to offset the focuser to do this. If the light cone convergence point is offset lets say 3 millimeters from the exact center of the focuser end of the tube, the focuser then would have to first be shifted that much (at the place where the measurement is taken) and then cocked to capture the light cone. No manner of shifting of the focuser without offsetting it can totally improve collimation if the basic collimation problem is with the optics end of the tube. Unfortunately there is little tolerance that would allow shifting a focuser in one direction more then a very marginal amount, before angling it.
On the bright side, while perfect collimation is great to have, a conditional collimation is generally ok and usually is "good enough" considering other shortcomings of the optical system that may also impact performance (particularly true in lesser achromats). At low powers, mediocre collimation can be tolerated to a degree, at higher magnifications it will be more of a factor. Precise machining and careful collimation is likely a very large factor in the price difference between the Orion ED 100 and the TV 102, or the Takahashi FS 102 or the AstroPhysics Traveler. For those that demand perfect collimation for any reason, the higher priced scopes usually have it due to better machining, tighter tolerances and better quality control. Accordingly they should receive top consideration.
Barry Simon
Posted 10/11/2004 09:34PM #1
Barry,
Thanks for a great discussion. On more than one occasion I have heard people talking about the merits of different tubes using the same Objective lens. Many say that everything is in the lens and that the tube is just something you look down. "At night all that matters is what you see in the eyepiece and who cares what the scope looks like in the daylight" I have always loved the build quality of scopes like AP, Tak, TBM, Televue and now you have gave me one more reason to appreciate these scopes. As usual Barry your comments come with content and useful information.
Dan
Danny Halstead
Moderator APM Forum
Posted 10/11/2004 09:53PM #2
Dan,
I do understand your point which is essentially - "Get it right at the beginning" then you won't need to consider collimation. One inherent problem with the Unitron refractors with collimatable cells (spring loaded ears that are 120 degrees apart)is that the easier they are to collimate, the easier they are to come out of collimation. (However once well collimated, the image improvement can be remarkable.)
2 years ago I bought a Vixen 102 f/9.8 achro tube assembly from Astro Stuff. It was a store demo unit in excellent condition. I bought it on condition that my Cheshire collimating tool proved that it was in good collimation as the cell is essentially not adjustable. It was "spot on" perfect so I bought it.
There is a lot of new stuff on the market now that can all add to miscollimation - cheaper diagonals with mirrors or prisms not properly seated and/or tube diameters both I.D. and O.D. which are either machined too large or too small, plastic components that you mentioned, or improperly machined or threaded objective cells, plus focusers with sag in the focusing tube. All of these individually "slight" problems can add up and contribute to a telescope which collectively may be a total collimation disaster.
Barry Simon
Posted 10/14/2004 12:25PM #3
Do you guys know how much, if any, of this collimation discussion would apply to f15 scopes? My f15 has an adjustable cell and seems to give good images, but I don't know if they could be made better by tweaking collimation. Am I correct that with an f15 there is a large "zone" of correct collimation?
Gary
