Iris Nebula
OrionAW120ST vs Skywatcher120F/5 vsAPM102Trip.Ref.
Started by Anders Asp, 11/17/2003 07:19PM
Posted 11/17/2003 07:19PM Opening Post
Hi!
I would like to know what u know and think of this scopes, witch one is the best all around scope, mechanics and optics and easy of use and setup. I'am looking for a scope with a wide field. I like to view most DSO and some planets and moon.
/ Anders Asp
Posted 11/17/2003 07:26PM #1
The 120mm F5 are both made by the same company and areopes are definitely not planetary scopes, lots of false color.
jon
Posted 11/18/2003 03:39AM #2
Anders,
I have the Orion ST120. It excels at wide field views. Any of the Televue Panoptic eyepieces will work well on this scope. I use a 27mm Panoptic which gives almost 3 degrees. However you need very dark skies to really see everything, otherwise you will just have a bright background sky. I use it on a heavy duty photography tripod, and it sets up very quickly. Top end power for this scope is around 75X-100X. Not really enough for planets and moon though.
David Simons
David Simons
Posted 11/18/2003 07:15PM #3
In my humble opinion, none of the scopes you mention are "best all around scopes". For best "all around achromat", I would look into something with longer focal ratio. Even with DSOs, you'll need high magnification for many of the GCs and PNs.
Ron B[ee]
