VDB 142 Elephant Trunk HOO
WO 80 FD vs Sky 90
Started by ddrake, 11/20/2007 04:06AM
Posted 11/20/2007 04:06AM Opening Post
A friend recently asked me to help fix up his Sky 90 as it had been determined that it was out of collimation. After getting that all done I decided to compare it head to head with my WO 80 FD. I tested them a number of times under different conditions and found the results somewhat interesting.
The WO has a fl of 555mm with an f/ratio of 6.9 and has fpl-53 glass and the Tak Sky90 has a focal length of 500mm and an f/ratio of 5.6 with a front flourite element.
The WO has always been a tremendous preformer for an ED doublet. The star test is quite good with only a slight hint of spherical aberration and virtually no color in focus. The Tak surprisingly showed significant spherical aberration in the form of undercorrection. To determine if it's significant to affect performance I slowly moved the focuser through focus and it was apparent that all the zones of the lenses were not quite focusing at the same exact point. The inside focus rings were very sharp and the outside focus rings were quite diffuse and il defined. While the focused image is respectable it didn't seem to deliver images that a first class apo should dliver.
While examining lunar and terrestrial features at high power the extra aperture of the Tak seems to deliver a slightly higher resolution image when compared to the WO but the contrast is definately better in the WO. This is confirmed by examining the the airy disk patterns at high power. The WO has a clean disk with a very dim first diffration ring on the brighter stars. The TAK definately has a brighter ring and hence a lowered contrast on extended objects. These are critical observations under high power it should be mentioned here. At most mags the Tak should perform quite nicely. The color is a little more noticeable in the Tak but is not at all significant while the WO is basically color free.
While it seems that the Tak isn't quite measuring up it should be mentioned that it is an f/5.6 which is extremely fast for a refractor. I do wonder how the 1.6X extender would affect the Tak. I know that color will be reduced but does it help SA? Anyways I thought I'd mention my findings here on the mart
ddrake's attachment for post 39761
Posted 11/20/2007 04:16AM #1
Thanks! Thats an interesting comparison, and not what I would have expected.
Posted 11/20/2007 09:07AM #2
Well, its a funny comparison, since the Tak is part of a system. Your supposed to use an extender-Q with it for visual use and a flattener for astrophotography. It gives you a "two scopes in one" type of package.
Sky 90 + Extender Q = f/7 (like your WO)
Sky 90 + Flattener = f/4.5
or with a small loss in quality you can use it at f/5.6.
I'm not sure the value of the comparison of the Sky 90 to your WO at higher powers without the extender Q. It wasn't intended to be used that way.
Daniel.
PS. If there is anyone in Perth Australia who'd like to compare the WO (or Skywatcher) to the Sky 90 w/Extender-Q I'd love to.
Posted 11/20/2007 12:50PM #3
No matter what the comparison I'm glad you feel the WO 80mm FD is a fine telescope. I just bought the upgrade to transform my SD to the FD and can't wait to see first light.
Mike
Posted 11/21/2007 02:32PM #4
Was this the older Sky 90 or the newer Sky 90 II? The newer ones I believe are supposed to have improved optics.
Eddie
Posted 11/22/2007 02:37PM #5
Are you using a prism diagonal? At F 5.6 the prism will inject significant spherical abberation and color. I have seen this on mine.
"--Granted, that's a worse case scenario. The destruction might in fact be ... limited to our own galaxy."
