Jay Messeroff
Lunar & Solar Transits
1" secondary for an 8" f8 primary
Started by klipy, 10/21/2003 02:02PM
Posted 10/21/2003 02:02PM Opening Post
Is a 1" secondary too small for an 8" f8 scope? I want to make it a good planetary scope. I will be mounting it onto an 1800 Destiny curved spider. Thanks for any suggestions.
Bob
Posted 10/21/2003 03:05PM #1
2 things:
If you go just up to 1.2" you will gain a lot of "wiggle room" in your design and sacrifice virtually nothing in contrast. At these diagonal sizes, half of your diffraction will be coming from the spider anyway. Also: find out if the Destiny's secondary holder itself, or its profile, is bigger than 1" if so then you wouldn't gain anything at all anyway.
Posted 10/21/2003 03:58PM #2
Bob,
I just built an 8" f/8 this summer and was contemplating a 1" diagonal but went with a 1.3" instead. I'm using a 10" ID tube, .25" wall, 1.5" focuser, w/.25" spare in travel. A 1" secondary provides too small a fully illuminated field. With a planetary scope, having a too small fully illuminated field not only means that the object becomes dimmer off axis (maybe noticeably, maybe not), but also you're reducing resolution because you're not using all of the primary.
Another thing to caution you on is with a very small diagonal, a defective edge (not uncommon in all but the best quality diagonals) is just like having a bad edge on your primary, and your images can suffer. IMHO, as long as you're under 20% CO, going even smaller doesn't do a whole lot in the best of circumstances, and can maybe do mare harm than good.
Good luck,
Doug Scobel
