2 refractor OTA's side by side with 2 diagonals??
Started by BoyntonStu, 04/11/2006 04:55PM
Posted 04/11/2006 04:55PM | Edited 04/11/2006 04:56PM Opening Post
What would the image be in each eye, same or different,
ABCD ABCD
DCBA DCBA
or upside down?
Is there an easy way to figure it or a site that shows it?
Stu
Posted 04/12/2006 01:30AM #1
Do you not own a single refractor that you can set up, and then with a switch sides with the tilt of the diagonal and move the stool to the other side? Pretty simple really.
Your only reqirement for this test is to keep your body orientation the same to the direction the scope is pointing. When sitting on the left side of the scope, you would view with your right eye. When sitting on the right side of the scope you would view with your left eye.
edz
Posted 04/12/2006 02:24AM #2
In general, to figure such things out I do a mental raytrace of a beam at the top (12 O'clock), and one at the side (say 3 O'clock), remembering that the focused image will be reversed. I.e., without any diagonals whatsoever, top stays top so it ends up bottom, right stays right so it ends up left. With a star diagonal, top becomes bottom so it ends up top, right stays right so it ends up left. Hope this helps,
-- William
Posted 04/12/2006 02:28AM #3
Stu,
Same, as others have stated.
Adjusting the interpupilary distance is the trick.
Here is a site you might enjoy and they are an ASTOMART sponsor.
http://www.binoscope.com/bigbino.htm
Bob
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
