I was doing some research about removing a warm air layer from the main mirror surface and found this article:
http://www.pha.jhu.edu/~atolea/WAS/thermal_management_newtonians.pdf
As far as I know, most of you guys are convinced that the best way to solve this problem is pumping air upward with a fan (fans) installed behind the main mirror. The author of the article says that the better way to deal with it is to install a fan that blows across the main mirror removing warm air through vents on the opposite side of the tube. It's quite convincing. With the back fan setup, even with extra baffle right above mirror, is one able to remove the warm layer from center region of the main mirror?
What do you think?
What do you think?
8" f/5.9 truss tube newtonian, made from scratch 8)
