Alt Bearings - Aren't They Pretty?
Started by web0178230, 06/19/2006 01:55AM
Posted 06/19/2006 01:55AM | Edited 06/19/2006 11:17PM Opening Post
[COLOR="Purple"]Well...not really but they look like they'll work okay. wink
These are the alt bearings for the long suffering 18.75" scope I'm building. Diameter is 23.25", heighth is 2" and they are 1.875" thick. The nice thing is they only weigh 2 pounds each. Adding the Ebony Star will add another couple of ounces to each. The nice Al bearings I bought weigh 10+ pounds each...too heavy for the semi-lightweight scope I'm building.
The ply is some stuff I found at the local hardware store...not exactly Baltic Birch but for the price not too bad at all. 11 plies and only a few small voids. Note the different colors of the wood. Each sheet had a lighter side and a darker side. The dark side should look nice facing out, with a very dark Ebony stain on it.
If I lean on one end with the other on the ground, there is a tiny (less than 1/8"?) bit of compression. Since the whole scope will be around 100 pounds, I think this will be okay.
I'm going to make them removeable for transport. Any suggestions on a "no tool" way to do that without having knobs sticking out?
Bill[/COLOR]
[COLOR="Maroon"]P.S. Can you tell that I was considering spoked bearings? Look at the lighter bearing and you'll see layout marks.[/COLOR]
web0178230's attachment for post 32095
Posted 06/20/2006 02:46PM #1
Bill Byrd said:
[COLOR="Purple"]If I lean on one end with the other on the ground, there is a tiny (less than 1/8"?) bit of compression. Since the whole scope will be around 100 pounds, I think this will be okay.[/COLOR]
If I remember right, Kriege and Berry in their book "The Dobsonian Telescope" say that spokeless altitude bearings tend to be "bouncy" when pointed at a low altitude. I don't think there's much danger of them breaking, but you may get a bit more vibration than you wanted.
