Philip Imbrogno
Elephant Trunk Nebula
Alternate Dobsonian Altitude Bearings???
Started by astro101, 12/15/2002 03:35PM
Posted 12/15/2002 03:35PM Opening Post
Typically when making a smaller DOB say 6-8", seems most builders will use PVC pipe sections. Then when building larger DOBS most builders see to use the very large semi-circlular wooden or aluminum framwork. Or just a large wooden circle with the formica attached. I wanted to know if anyone has found a readily available source for round "disks", or whatever they used for the altitude bearings.
Thanks
STeve
Posted 12/15/2002 03:49PM #1
I used PVC for my 10" dob alt bearings and it works great. You can get pre-cut plywood discs at Menard's or Home Depot if you don't like to cut circles.
