Ghost of Cassiopeia
Altitude bearing - Dob too loose
Started by rchozick, 09/08/2004 07:41PM
Posted 09/08/2004 07:41PM Opening Post
I am building a base for my Dob and the Altitude bearing is too loose. I have tried sanding the Ebony Star until it is smooth and adding more teflon. It is fine in the middle altitudes but as it approaches 0 and 90 degrees the scope falls. No amount of balancing helps. Someone told me my bearings are too small but I would love to fix it as and not have to do a major modification. I have a 10" scope and the bearings are 7" in diameter. Does anyone have a suggestion on how to give it more friction or at least more friction on the ends of travel? Would a spring system work? Thanks.
Posted 09/08/2004 07:59PM #1
Can you post a picture to give us an idea of what you are dealing with in this?
Floyd
Posted 09/08/2004 08:53PM | Edited 09/08/2004 08:55PM #2
Robert,
From your description, it sound like you could fix it one of two ways.
In a statics equation you get the moment of the scope (cg*distance) is equal to the moment carried by the bearings. The moment of the scope is the horizontal distance of the center of gravity of the scope to the pivot point * weight of the scope. The moment at the bearing is the frictional load * radius of the bearing.
Fix 1.
When the frictional load required exceeds the capability, the interface slides (scope falls). The frictional load is the force normal to the surface * coefficient of friction. You can bump the coefficient of friction by roughing, but some scope companies instead increase the force by adding a spring that pulls the scope down. I'd add a turnbuckle to the spring to make it adjustable.
Fix 2
The center of gravity is not at the pivot point. As the scope moves the horizontal distance from the cg to the pivot point varies. This distance is at a maximum as you lay the scope out horizontal. The weight is constant so the moment created by the scope and thus carried at the bearing is directly proportional to being horizontal. At some point, this moment is too high to be carried by the friction at the bearing. Counter weights (balance the scope), should move the cg close enough to the pivot point to get within the working limits of the friction. (i.e. if the cage falls, the cg is above the pivot point, add weights to the box and the cg is lowered).
Ed
Posted 09/09/2004 12:38AM | Edited 09/09/2004 12:46AM #3
Making the altitude bearings larger will help as your friend mentioned. Of course the other solution is to add an easily adjustable counterweight, though balance may still be tricky.
I have a similar problem to yours. Aside from any problems with the center of the tube be balanced at the altitude bearings, I have a problem with the scope being too easy to move, so that balancing the scope is not possible for even a small variation in eyepiece weights. I am using altitude bearings which are slightly small because they are actually stored inside the mirror box of my scope, which is designed to be as compact as possible.
I think I will need to go with the spring-tension arrangement, similar to the commercial dobs. I would like to try PFA.
--Ian
Posted 09/09/2004 12:46AM #4
Others have suggested the right way to do it. (My favorite choice is moving the pads further out.)
However, one other suggestion, is to wrap some clean masking tape over the teflon, or electrical tape. See how the added friction helps. If you don't like it, take it off.
Posted 09/09/2004 01:23AM #5
After building a few dobs, all with 8 inch bearings, I find it hard to believe that your telescope is balanced correctly. The 7 inch bearings should work OK for your 10 inch scope. Typically it is the eyepiece end that falls down, is this so, then you need to add some weight at the mirror end. If the eyepiece end is still falling, then you simply need to add more weight. Also moving the pads further out will help, as was previously discussed. Some have even put the soft sided velcro over one of the teflon pads on each side to add some friction.
Posted 09/09/2004 05:01AM #6
Thank you all so much for your advice. All I had to do is move the teflon further out. It is still smooth but does not fall. The balance issue is not a problem. I mounted my altitude bearings on a steel bar connected to the rings that came with my 10" Orion reflector. It is now very easy to change the tube orientation and up and down. I allowed a lot of room to adjust by making my sides 24" high. I just have to mount my encoders and I will be ready to go. I am really nervous about the altitude encoders. I am uneasy about committing a 3/8" hole to what I think is the center. I will post a picture when it is finished. Thanks again.
