I placed a very small dot (using white out) at the center of my secondary believing that lining it up with a cheshire would be made easier. It also aligns very well with a laser. I can see the laser hit the dot (using a hand-held mirror) and hit the center of the donut.
But when I collimate my primary the dot does not appear inside the donut. It is just out about halfway between the center of the donut and the edge of the cheshire tube.
It could be I have not found the exact center of the secondary. However the previous owner had placed a very small black dot on the secondary that I took to be the center. I used the white-out to see the dot better. It measured out close enough to be the center.
I've read about optical verses mechnical alignment but I'm stumped. I would appreciate some help in understanding whether or not the dot should appear in the donut for the scope to be properly collimated. Or is this evidence of the proper offset I've read about. The scope is a Coulter 13.1 inch f4.5 with the original secondary.
Thanks
DCR
Thanks
DCR
