Can you crack the code?
Started by Gary Pakalski, 05/18/2005 03:20AM
Posted 05/18/2005 03:20AM Opening Post
Hi All,
I have a 16" mirror that came out of a M**de Dobsonian telescope. It has markings on the back (in Magic marker). They are a series of numbers printed in a vertical column as follows:
.3
-.7
.1
.1
.5
.7
There is a small 7.36 written next to the last .7
Any decoder rings out there?
Gary Pakalski
Posted 05/18/2005 01:24PM #1
Sounds like zonal readings from a focoult test to me. The 7.36 is probably the radius of the outermost zone.
Jarad
Posted 05/20/2005 08:36AM #2
I too suspect that they are test readings of deviation from optimum. If the numbers were .003 -.007 etc. I'd be much more comfortable in saying so.
This is a mass produced factory mirror - perhaps they set up their test apparatus for a +1 and -1 tolerance level and if all readings fit within these tolerances they pass inspection. Then you don't need an experienced optician to preform the test.
Just a thought.
Bob
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
