Iris Nebula
Can you help me identify this lever thingy?
Started by dwalton, 11/09/2007 07:00PM
Posted 11/09/2007 07:00PM | Edited 11/09/2007 09:48PM Opening Post
Hi everyone,
I've attached an image that shows a red-handled lever on the side of a dob rocker box. I believe the way it works is like a lever "switch" - when the level is push all the way to the left, it pulls on a rod on the inside of the rocker box, and when moved all the way to the right, it pushes the rod back in the other direction. I also think it sorta locks in place at either end of its throw. It functions as an azimuth drive engage/disengage lever.
My question: what are these called, and where can I get them (or something like or, maybe better?)? It would be great if I could get one or two with some kind of adjustable-length connecting rod to go with it.
Thanks!
Doug
dwalton's attachment for post 39620
Posted 11/09/2007 07:39PM #1
Hello,
That lever thingy is called a de-sta-co clamp available at destaco.com. I think Mcmaster-carr has them, they are also available at woodworking places as work holding clamps. They are great for fairly high force applications.
Cheers, Eric
Posted 11/12/2007 07:30PM #2
Doug,
Do you happen to have a picture of the inside of the focker box? I am wondering exactlyhow this clamp/lever attached to the rod that controils the Azimuth bearing.
Thanks digging this pic out and posting.
Posted 03/12/2008 03:21PM | Edited 03/12/2008 03:22PM #3
Doug Walton said:
Hi everyone,
Doug
Hi Doug,
Not sure if you still own your StarMaster, but I just implemented a design that would bring the Azimuth adjustment lever to the outside of the rocker box. I have attached a picture...
See the thread I started here in the StarMaster Forum for more pictures.
http://tinyurl.com/ysj9hd
peleuba's attachment for post 120966
