james carter
North American Nebula NGC7000
Cast Aluminum Rotating Rings
Started by TheDesertSage, 06/06/2007 02:23AM
Posted 06/06/2007 02:23AM Opening Post
Hi - I'm refurbishing a 17.5" scope and am considering the fabrication/installation of fully rotating rings. I've made these before using large aluminum castings (these rings will be 25" OD X 22" ID X 1.5" thick. Unfortunately, I don't have a pattern anymore and this could be cost-prohibitive to produce without one. Has anyone else here attempted to make a large aluminum ring like this? Is there any such thing as an aluminum pipe this size or a way to "roll" bar stock to such a radius? Any advice appreciated! Thanks! - chuck
Posted 06/12/2007 06:43PM #1
Here is what you want: http://www.rockler.com/product.cfm?Offerings_ID=10514&TabSelect=Details . For more choices of large Lazy Susan bearings, look up www.mcmaster.com and search for "Lazy Susan".
I have also made a large rotating bearing, about 24" ID, out of 3/4" x 1/8" aluminum angles. I built a ring roller using three polyurethane keel rollers (used on boat trailers). It works well but was quite a bit of work to build it.
Posted 06/13/2007 12:26AM #2
Use aluminum plate of the desired thickness, Use a compass to mark your circle then cut. Plywood is an excellent aluminum substitute.
A local machine shop could do it cheap and fast and squared.
