Center spoting my mirror
Started by jimmoscheck, 03/21/2007 11:40PM
Posted 03/21/2007 11:40PM Opening Post
I've never center spotted a mirror before and I'm to the point in my telescope where I have to do it. My XT10 came with it's reinforcement ring installed.
I just got back from Staples and they didn't have the old paper style rings you had to lick, but new ones made of plastic with self adhesive on the back. Are these OK to use on a mirrors surface? I tested one on my car window and it was very difficult to remove so the adhesive is pretty strong.
What kind of adhesive do the Jim Fly center targets use? Maybe I should just order one from him. :S
Posted 03/22/2007 12:07AM #1
Jim
They worked for me and should work fine. The Catseye triangles are pressure sensitive also.
Buck
Posted 03/22/2007 12:15AM #2
Jim,
The best thing is Jim's template. It works great for getting a perfect center. You can use regular round ones too, but I do like the triangles, they show up well and work fine with the template and his tools. Worth the few dollars and is reuseable and fits many sized mirrors.
Posted 03/22/2007 01:40AM | Edited 03/22/2007 04:10AM #3
This is really for all responders. Has anyone used an oversized center spot? Seems in my chesshire there is a dark spot represented by the peep hole, and the mirror center spot is about the same size. With a red light at dark they tend to superimpose when in collimation. However, it would seem that the collimation would be more accurate if the center spot was of a large enough size so it would leave a illuminated concentric ring around the reflection of the "dark" hole from the chesshire peep. This would be somewhat similar to the Jim Fly collimator where the large reflective donut of the collimator is concentric outside the centerspot. We tend to not want to put something too big on the mirror, but the area is unused anyway "astronomically speaking".
I Yam What I Yam!
