Considering building my first telescope
Started by mperron, 03/10/2008 04:23PM
Posted 03/10/2008 04:23PM Opening Post
Hello all,
I am considering building my first telescope and was wondering if anyone could point be in the right direction as to what would be a good first book for a complete newbie.
I've been doing astronomy now for about 10 years so although I'm very familiar with telescopes, I don't know the first thing about ATM and would like to learn more. I'm thinking of a 6-8" dob for starters as it seems like the complexity, mirror size and cost (in case I completely ruin things) are all reasonable.
Thanks for any help.
Mike
Posted 03/12/2008 02:52PM #1
Mike,
All good advice so far. I just finished my first dobsonian mount. I second the idea of sticking with a plan, Berry's or other's.
Just one point about the rockers and altitude bearings. Berry menions that one should build the cradle supports seperate from the rocker box for adjustments as needed. A very good point for sure!
I found that even though I worked both the bearing supports and box sides as pairs, when assembled the bearings did not make contact on all four pads (three pads did make contact). This made the scope rock.
The solution for me was to cut a slot,as wide as the bolt that held the low pad, down to that bolts position. This allowed me to adjust the cradle support. This eliminates a second/third or more guess to where it should be and if the adjustment is small one does not need to enlarge the hole in one direction.
Hope this is helpful.
Scott
