cutting aluminium
Started by Falling-leif, 06/16/2003 02:36PM
Posted 06/16/2003 02:36PM Opening Post
For those of you that build telescopes out of aluminium parts, what kinds of tools/blades/bits do you need to cut aluminium sheet or "L" stock.
Posted 06/16/2003 05:17PM #1
Harbor Freight Tools sells a special metal-cutting bandsaw for $200. It works great on steel and aluminum. The blade runs at a much lower speed than a wood bandsaw, which is what you need for cutting metal without a coolant or lubricant.
Posted 06/16/2003 09:21PM #2
Also, a metal cutting blade for a hand-held jigsaw works too. Its not as pretty as a band saw cut, but as Mitch said, it can be touched up with a hand file.
