Jay Messeroff
Lunar & Solar Transits
DIY Alt Az Mount with Slip Clutches ?!?
Started by Peter Glus, 07/18/2007 02:50PM
Posted 07/18/2007 02:50PM Opening Post
Ive been fristrated at the price of commercial alt az mmounts. Most don't have slow mo controls, and when they do there is no slip clutch (I am hooked on slip clutches since I own a CI700). Hence, I am setting out to DIY!
For my AZ, i was thinking of a two-disk system. Teflon between the top and second disk would provide the slip clutch. A worm gear (actually the second disk) would provide slow mo controls. I could even get some cheapo meade dx motors and have hand paddle control.
For the Alt, I was thinking of a slip clutch on the horizontal shaft made using two collars, a spring, and some teflon washers clamping the spur gear.
The mount would have a 20 - 24" horizontal shaft that could possibly mount two scopes. I think the Alt arangement would be plenty stable. Have some concerns about the stability of the disk arrangement. Could place teflon blocks around the circumference to keep things stable.
Am I reinventing the wheel, or even worse, heading down the path to ATM hell?
See my bad sketch for a horrible visual.
- Peter
Peter Glus's attachment for post 37932
Posted 08/05/2007 08:59AM | Edited 08/05/2007 05:15PM #1
>>Ive been fristrated at the price of commercial alt az mmounts.<<
Not I. I followed the examples of others, like these guys:
http://www.astromart.com/forums/viewpost.asp?forum_post_id=241698&poll_id=&news_id=&page=
http://www.rtmcastronomyexpo.org/archives/photos/2004%20RTMC%20AE%20016.jpg
http://www.astromart.com/forums/viewpost.asp?forum_post_id=452610&poll_id=&news_id=&page=
No clutches here, but definately affordable and very well working IME.
And another thing!
Here's examples of a Berry type mounts, for big and little scopes:
http://members.leapmail.net/%7Eericj/refractordobmounts.html
http://www.homebuiltastronomy.com/kidpeek/index.htm
Posted 08/05/2007 10:56AM #2
Peter:
My solution to this particular dilemna has been a bit of "junk yard" engineering. Old EQ mounts are often quite inexpensive and by simply pointing the Polar axis to the Zenith become a ALT-AZ mount complete with nice Slo-motion controls. In this scheme, the RA axis becomes the Azimuth axis and the Dec becomes the Altitude axis.
Smaller ones generally work nicely without any modifications but larger EQ mounts rarely are capable of pointing at the Zenith without some surgery. I recently converted an old Meade LXD-500 mount to an ALT-AZ mount for use with a variety of smaller scopes, my 80mm MegrezII FD as well as a 5 inch F/5 Newtonian.
There is a learning curve like any mount and clearly some mounts are better suited than others. I like mounts that allow the head a full 360 degree rotation on the tripod, I use that for the course azimuth adjustment and the slo-mo controls for the fine adjustment. I like to eliminate the counter weights so this helps keep the weight of the scope closer in. There can also be clearance issues as with any mount, it is best suited for shorter OTAs.
For me, these do the job. The scope is balanced like most commercial ALT-AZ mounts but has the added advantage of the nice slow motion controls as well as reasonable setting circles. For the low power work I can use it "point and shoot", great for roaming around the sky just looking. When I dial in on a target and want to crank up the magnification, I can use the slo-motion controls to precisely center and then track the targets, it is really the best of both worlds.
Here is a picture of my Megrez II 80mm FD mounted on the Meade LXD500 mount. I have a smaller MEade mount (one from a 4500 4.5 inch F/8 Newt) that works reasonably well with scopes this size but I had the LXD-500 and I wanted to give it a try.
This is not for everyone but it is an interesting option and has some nice advantages.
jonisaacs's attachment for post 115868
