Jay Messeroff
Lunar & Solar Transits
Extending Aluminum Tubing?
Started by web0178230, 09/08/2005 02:46AM
Posted 09/08/2005 02:46AM Opening Post
[COLOR="Purple"]I'm hoping the pic attached will help get this idea across. I'm going to need truss poles about 7' long for the scope I'm building; 18.75" f/5.2. A few years ago I bought some poles for a good price. The problem is that they are only about 4.5' long. In the picture you can see that I have some thin wall tube that fits very snuggly into the 4.5' tubes I have.
My question is: Can I get away with using the inner tube as a splice to butt pieces of the larger tube together? Gap filling super glue or epoxy would probably make this a very strong connection between the three pieces.
If that isn't feasible, I'll probably have to get 12' pieces from Texas Towers and cut off 5'. Not a good alternative considering cost and shipping for 12' Al tubes.
Has anybody ever done something like this?
What about making these into two-piece poles? Use string to add tension between the mirror box and upper ring to keep things together...sort of a string scope but not really. That would allow me to have truss poles about 3.5' long, which would be nice.
Any thoughts?
Bill[/COLOR]
web0178230's attachment for post 26660
Posted 09/08/2005 03:22AM #1
A guy I had built a 12.5 inch for ended up getting a new mirror with a longer focal length. He found some tubing with an ID a little larger that the OD of my original tubes, and spliced it in with pop rivets. Turned out pretty stiff, although not as stiff as originally built. He also had to add some weights to the back to get it back in balance. Haven't seen that scope in a while.
Posted 09/08/2005 04:40PM #2
I think that you could do it. With the truss poles you are primarily concerned about deflection and they are plenty strong to handle the stress. You could probably get by with through bolts so that it could be easily disassembled.
A company called S&S Machine makes some fancy couplers for bicycle frames, these allow standard road frames to be disassembled. I would imagine they cost more than any savings you would gain though.
jon
Posted 09/09/2005 05:13AM #3
Hello:
I think it should work. The stresses are distributed over 8 poles so the force at each joint wouldn't be that much. A good epoxy (I have JB Weld in mind) should easily be able to handle this job. I'd keep the overlap region longer than the tube OD for added stability.
Cheers
Mike Connelley
Posted 09/09/2005 06:35PM #4
Find someone building a scope that needs 4-5' poles and plit the cost of the new poles.
Ed
Posted 09/09/2005 11:47PM #5
[COLOR="Purple"]Thanks all!
You've given me a lot to consider, pro and con, for what I had thought about doing.
To expand on my idea a little: I was thinking of at least 4" the inner tube inside each part of the larger tubes. I was thinking epoxy to hold things together but I hadn't considered the expansion/contraction issue. I guess I'll glue one up and see how it does.
I haven't bought Al tubing from the one place I can get it here in S TX in several years. As I recall, it wasn't cheap. Hence my desire to use what I already had if possible. Maybe I'll revisit the metal supplier to see what I can get and at what price.
I'll post results as they become available.
Thanks!
Bill[/COLOR]
Posted 09/11/2005 09:00PM #6
[COLOR="Purple"]Well, I got three pieces (two ends + middle, inner splice piece) cut today in preparartion for gluing (with 90 minute, high strength epoxy) up a trial run 7' 3" pole. But....7' truss poles are VERY L O N G !! Even if gluing works like a charm, I'm not sure I can transport 7' truss poles on a regular basis in my little scope hauler without resorting to using the roof rack, which would have to be installed each time I wanted to go observe.
Sooo...back to an idea I had for a much smaller scope: two piece poles. The pic shows the parts that went into the prototype, which was 1" OD....much smaller than the 1.25", thicker walled tubes I have to work with for the 18.75" scope.
I ended up selling the mirror for the smaller scope so I never finished a working scope with the two piece poles.
Anyone have experience making two piece poles and if so, how was it done??
Bill[/COLOR]
web0178230's attachment for post 95888
