Has anyone fiberglassed over sonotube to increase rigidity and enhance the apperance of the tube? What weight cloth do you use, what type of resin (polyester or epoxy) Any info would be appreciated, thanks, Vince
Fiberglassing sonotube
Started by vbert, 11/07/2004 04:20PM
Posted 11/07/2004 04:20PM
Opening Post
Posted 11/07/2004 05:15PM
#1
Thanks Steve. I considered having my surfboard shaper do it but he wants too much $$. would it be easier to use spray adhesive to hold the cloth? Just so I get this right, do first cloth layer, wet out with epoxy, let set, then second cloth layer, wet out with epoxy, let set, then final coat of epoxy. Also, about how much epoxy do you think I would need for a 12" dia, 68" tube? Thanks again, Vince
Posted 11/08/2004 02:24AM
#3
Vince,
I don't understand why anyone would want to cover Sonotube with fiberglass. Sonotube - at least real Sonotrube - is plenty stiff enough and heavy enough without adding weight. The best thing you can do to stiffen it is to add some good end rings.
I spent a lot of time finishing a Sonotube many years ago - removing the wax, sanding and filling, and then painting it. It was a lot of work. With the last seven or eight tubes I've made, I've left the wax on, covered the tube with a nice celestial fabric (Hoffman Fabrics has some great ones), and then Scotch guarded it. They look great, are easy to do, and hold up exceptionally well.
I've attached a photo of Sue's cloth covered 14.5" f/6. The aluminum piece on the front is a light shield that slides on.
Clear skies, Alan
Clear skies, Alan
Funding Member
