[COLOR="Purple"]In keeping with the constant theme for the 18.75" ATM project of doing everything multiple times, I'm now trying to salvage the USA (Upper Support Assembly) after applying the poly spray on finish yesterday. Dummy me had used a Sharpie marker to blacken the rings. Unfortunately, something in the Sharpie chemistry does not play well with poly. I sparayed several coats on the entire assembly before I noticed that the areas where I used the Sharpie were not curing. On the dowels, which had been stained with regular Minwax red oak, the finish set up just like it's supposed to. On everything else, the finish stayed tacky and never set up.
"Note to self: Do NOT use markers as a stain if finish is to be applied!!"
Rather than strip everything, which would be very messy and mess up the nice stain on the dowels, I am "rubbing out" the tacky areas using tung oil. This seems to get the tacky residue from the poly off and I'm hoping that it will cure where the poly would not.
If this fails, I'll have to strip all of it and just paint the whole flipp'n thing flat black. Boring!!
Bill[/COLOR]
Bill[/COLOR]
