Finished upper cage, onto mirror box....
Started by Grumpy_one, 06/15/2009 05:50PM
Posted 06/15/2009 05:50PM | Edited 06/15/2009 05:57PM Opening Post
Using Kriege/Berry book. Is there anything I should consider before construction(i.e. height, inside dimension's)? For example, upper cage id wasn't totally accurate in the book (apparently on the small side) and followed advice from here (thanks to all who contributed). Upper cage weighs in at about 10.4 lbs with heaviest eyepiece and barlow, and pretty much completed. Going to verify focal length (about 80"). 12.5" two inch thick primary. Using 1" OD truss tubes. .049 thickness. As best as I can tell, the distance from the secondary to the top of the focuser racked in is about 9 3/8" The book talks about a spread sheet, I'm attempting to make one. If anyone has insight to go about this, I'd appreciate it. Thanks!
(I'll post pic soon)
Posted 06/16/2009 12:07AM | Edited 06/16/2009 12:08AM #1
As promised. I still have to do the finish.
Grumpy_one's attachment for post 130861
