Flocking inside of upper cage
Started by Grumpy_one, 05/01/2009 05:28PM
Posted 05/01/2009 05:28PM Opening Post
What have you used, what works well? I looked at Protostar's flocking paper, which would be awsome. But being as cheap as I am, what would work from say a fabric store? 5.00 to ship a piece of paper is a bit pricey for me. Thanks
Posted 05/01/2009 05:48PM #1
I believe there is a comparison review of materials on cloudynights.com that would be a good starting point. They really liked something from JoAnn fabrics.
Posted 05/01/2009 07:07PM | Edited 05/01/2009 07:08PM #2
I was a part of the testing that was done on CN concerning the fabrics. It was found that a Velvet was about as good as it gets. I found one called "Madonna Black", which was a particular brand, that was excellent.
If you just go to the fabric store and take a velvet and use the harsh lighting you can check the incidence reflection right there. Also, a flashlight can be used effectively by shining it at the cloth and noticing how much of the light is reflected and absorbed. The Madonna would just show a circle of dim light where the flashlight was shined on it.
Gluing it to the inside is another story! Your best bet is to roll it up on a dowel or tube and then spray or brush glue as you unroll the fabric and smooth the wrinkles. Doing this a couple of inches at a time will result in a good smooth flocking. Be sure to cut the edge cleanly and if possible sear it with a lighter so that the edge will not unravel, this can be a major pain as the strings try to glue to everything. wink
Also, make sure not to try to use stretch fabric, that is really hard to apply. A quality velvet will cost $10-14 a yard.
This is a pic of my scope flocked with Velvet.
fblue's attachment for post 130067
Posted 05/01/2009 08:46PM #3
Black velvet is what you want. The most critical
area to flock is the region visible to the
eyepiece opposite the focuser. You might not
need very much material, depending on the details
of your scope.
