giant old fashioned metal mirror?
Started by yahganlang, 05/24/2006 02:24AM
Posted 05/24/2006 02:24AM Opening Post
In the days before precision glass mirror-making metal mirrors were the norm- some quite large. What kind of figure did they have and keep? What would they be like using today's figure types (such as wave or Strehl values)? I'm already aware of their tendency to tarnish, which upon repolishing might significantly alter the figure.
What kind of images would they be able to give (say, of near galaxies) if one had one with a diameter of six feet, versus a modern glass mirror of same figure and size?
Jess Tauber
Posted 05/24/2006 01:10PM #1
Hello:
From what I've read, those big metal mirrors were a pain in every way. Asside from the constant repolishing (and thus refiguring), there were many other problems, perhaps not due to the use of metal per se. Warping was a serious problem, but back in the 18th centrury they probably didn't have fine annealing or 27pt flotation cells. One recent experience brough home the supremacy of glass mirrors. It took a 72" speculum mirror to discover the spiral arms of M51. I recently looked through a 19" scope (with new silver coatings), and the spiral arms were not subtle. I could trace the arms for nearly a full revolution around the galaxy. This, with a scope having 14 times less light gathering power.
That said, good metal mirrors are currently in use. The Spitzer space telescope's mirrors (not to mention the rest of the telescope) are solid beryllium. The mirrors for JWST (should it ever get built) will also be beryllium. The same friend with the 19" is part of an experiment which will use 4 aluminum mirrors, i.e. the company ground and polished the mirror surface on disks of aluminum. These breyllium and aluminum optics are for space or other special uses. For more pedestrian optics, glass is still the most practical material. All modern large telescope built today still use glass mirrors, despite efforts to find other substrates. Silicon carbide is a promising material. The observatory I work at has several SiC secodary mirrors, which are amazingly light. I have no idea how much they cost, as one was made in Russia.
Cheers
Mike Connelley
