Glue for Ebony Star
Started by stuper1, 04/19/2008 12:37AM
Posted 04/19/2008 12:37AM Opening Post
What's the best glue for attaching Ebony Star to plywood?
Do you have any tips on the process, such as how much glue to use, or anything else I should know to make it easier? Should I put the glue all the way to the edge or stop a little short so it doesn't squeeze out and make a mess?
Thanks.
Posted 04/19/2008 12:43AM #1
[COLOR="Purple"]Hi Stuart!
I use contact cement. Others have used carpenters glue but it's harder to clamp the ES to the plywood because it wants to slip and move around.
I'd glue all the way to the edge and clean up any squeeze out after everything sets up. If you leave a void at the edge, you might have issues later on.
Bill[/COLOR]
Posted 04/19/2008 07:25AM #2
I use professional contact cement made for the application of masonite to wood. Works well, but others I know use carpenters glue and just tape it in place until it sets up.
Posted 04/19/2008 03:01PM #3
Forget about using carpenter's glue for your laminate. It's made to work with porous materials and will not work well with laminates.
Contact cement is the preferred glue for laminates.
dan kowall
Posted 04/19/2008 03:51PM #4
In my cabinet shop we use 3M High Strength 90 for flat work.
It's ready when it doesn't "leg up" when you touch it, or smear. The temperature and humidity might affect the bond, so do it where it's warm and dry, but not near an open flame or in an unventilated space! Be sure to hammer it with a rubber mallet to establish the bond when you're done. Hand pressure isn't enough. Long sticks placed between the laminate and the substrate will help you position it, then withdraw the sticks one by one. Leave a bit of overhang and then route it flush. Sand or lightly break the edges, they can be sharp!
For curved surfaces, there's a different procedure.
Posted 04/21/2008 05:02PM #5
Gorilla Glue works too. Just follow the directions on the container. Just chisel off any glue that squeeze out.
