how to cut laminate?
Started by marcin, 06/02/2008 03:36PM
Posted 06/02/2008 03:36PM Opening Post
I tried to cut Ebony Star laminate yesterday using a pair of sheet-metal scissors. It started cracking and crumbeling, causing small flakes of the outer layer to fall off. Is there a way to get a nice, clean cut?
Also would you glue the laminate to an unstained or already stained wood? Is a contact cement good for this purpose?
Thanks
8" f/5.9 truss tube newtonian, made from scratch 8)
Posted 06/02/2008 04:43PM #1
[COLOR="Navy"]***Shears will work. Only one side should flake, so just have that side of the shears face the scrap side. A carbide tooth scoring tool will do the job, too. Just do a couple of passes against a straight-edge and snap it off. The tool is just a few dollars. A fine-toothed carbide blade in a table saw is the easiest and most accurate way to cut laminate strips.[/COLOR]
Thanks
[COLOR="Navy"]***Contact cement is the glue of choice for laminates. If given the choice, unstained wood would be the best substrate.[/COLOR]
dan kowall
Posted 06/02/2008 05:16PM #2
Thanks
I use my table saw or radial arm saw and a fine tooth blade made for such materials. It gives me very nice smooth edges.
Oklahoma State University--The University of Oklahoma!--GO POKES!! GO STATE!!
