[COLOR="Purple"]It is a telescope...finally!! It's taken a couple of years but the 18.75" f/5.2 cellular mirrored scope lives! It's not completely done yet but it's close. I took a few days off from work hoping for a night of observing. I took the scope out to the sorta close by observing spot last night and tried it out for 3 hours.
Since it's not completely done the following were detriments to the use/views:
No heat shrink on the truss poles
Mirror & rocker boxes not blackened
No upper baffling to block stray light
No felt pads to keep mirror box centered
New finder location never really tried before
Cooling fan not hooked up - not really a problem with
the cellular mirror
I figured I'd just go out for an hour or so since it was nice and clear...see how it went together, how it moved and how I would do with having to use a ladder for observing. If I was able to have even so so views, I would be happy.
As it turned out, the night was pretty good sky wise and scope wise. First hurdle was fitting the largish rocker box and mirror boxes in "Scope Hauler" my PT Cruiser. As you can see from the pic, it fit but just barely. Poles and ladder rode on top of the stuff in back. I left the rear seats in the PT and just folded them forward...didn't have to remove them. Sooo...this can be a (sorta) grab and go set up since I can throw everything in the PT and be on the way in about 5 minutes. Not bad!
Set up in the dark went just fine. Collimation was easy. First views were a little soft and I was afraid maybe the simple mirror cell was not providing enough support to give good views. After about 20 minutes, the views were very good, so I'm pretty sure the first views were suffering form mirror/structure cool down issues.
All eyepieces reached focus (5-6 careful trims of the truss poles) except for the 12mm Nagler, which needs a lot of in focus when used with the Paracorr. Speaking of the PC, It may not be needed all of the time. I did some viewing with and without...a little better with...more FOV without and still pretty good. More viewing time will tell if the PC will be used much...maybe used for the longer focal length EPs and not with the shorter ones?
The views were definitely brighter than the 14.5" I'm used to using. Not a jaw dropping difference but definitely brighter. It may have been my imagination but I had the impression that more stars had color than in the 14.5". For example, M13 had 4 stars in the cluster that appeared much redder than I ever remember seeing.
I'm not crazy about having to use a ladder when observing but I guess I can get used to it. My old knees were complaining after two hours of up and down. Taking a short break every 10-15 minutes helped.
The place I was at is not the darkest. I mostly vivisted old favs while evaluating the performance. M31 was of course a showpiece...very bright and filled the FOV of even the 26mm Nagler. M13 was great! I looked quickly for the IC galaxy that lies close to the cluster but didn't see it. The NGC galaxy a little further away was very easy so the IC galaxy might just need a darker sky and more concentration on my part. Strangely, the Veil wasn't a lot better than in the 14.5" but it might have been the seeing.
NGC7789 was very nice. The Ring was brighter and it seemed like the center was more filled with nebulosity than with the 14.5". All in all, not bad at all!
The two piece truss poles performed just fine! I was afraid that there would be some "slop" from the joint where they screw together but everything was pretty solid once the poles were locked down top and bottom.
Having given the scope its first "real" use, I now have a few things to finish up. Since I was off today, I've already made the last cut on the truss poles to finalize their length. As much as I like the KineOptics focuser, I really missed having a non-rotating two speed focuser so after much consideration, I installed my old focuser. It's much heavier but I'm slightly back heavy at this point so I should be okay. I just tested the heat shrink I bought a while back and it works okay for being 11 years old. The areas where it was flattened in the roll don't flatten out like the newer heat shrink but it's not bad enough to make me go out and spend a lot of money on new stuff.
I have real pebbled Ebony Star on the alt bearings and glass board on the rocker box. Movements in both alt and az were a little stiff so I need to do some fine tuning. My alt teflon pads are the size K&B suggest...maybe the imbalance hurt the movement...maybe I need to clean the bearings and ES. The az teflon pads are a little small according to K&B so I'll put some larger pads on tomorrow and maybe shim the center pad a little more.
I'm off tomorrow too so I plan to paint, shrink, trim as necessary to get as much done as possible so this scope will be ready for a trip to really dark skies next month in west Texas.
Anyway, I'm sorry to ramble so much but it sure was nice to get out and try this scope after all of the time it's taken to put it together! All of you ATMs out there can appreciate the sweat equity that went into a scope like this so I thought I'd share.
Bill[/COLOR]
the cellular mirror
Bill[/COLOR]
