I've just started and now I need a finish
Started by jimmoscheck, 10/24/2006 01:44AM
Posted 10/24/2006 01:44AM | Edited 10/24/2006 01:46AM Opening Post
Hi All,
A few questions about stains and finishes.
I've just completed the UTA and I'm ready to put the finish on the rings. I've finished lots of projects with good results, but mostly darker woods like oak and walnut. I'm using imported Baltic Birch and Maple for the split blocks both of which I've never worked with before. I just tested a few stains that I had on hand on the inside circle from the rings and they came out a little blotchy. Should I use a conditioner before the stain? I haven't decided yet on what stain to use if any and I'm leaning towards as natural (light) a color as possible. For the final coats I think I should use spar urethane and not polyurethane, correct? Has anyone finished one using just the Spar and no stain at all? Also, what finish of the spar, satin or gloss?
Any comments or advice is appreciated, and any example pics of the finishes on your scopes would be great,
Posted 10/24/2006 02:58AM #1
If you use just the Spar Urethane then the natural gloss and color of the wood will come out. It makes a very nice finish. It will also turn slightly golden with age which also is very nice.
Plywoods are more difficult to stain and that is why you are seeing the problem.
I prefer the look of natural wood anyway. So no stain is fine for me.
Posted 10/26/2006 06:14AM | Edited 10/26/2006 06:16AM #2
I must recommend this great book on finishing.
Understanding Wood Finishes by Bob Flexner. Published by Rodale.
He simplifies much of this stuff and puts it into easy-to-understand, no-nonsense terms.
One of his primary goals is to unveil the finishing materials, so you know what you're actually dealing with.
Most of the manufacturers want you to believe they have some kind of secret formula. Many myths are debunked.
I went to one of his seminars once.
It's been a big help to me.
Linton
