Looking for air filter ideas
Started by djscobel, 08/15/2005 02:04PM
Posted 08/15/2005 02:04PM Opening Post
Since installing blow-across fans on my 13" Dob, I'm finding that I'm now blowing a lot of dust and dirt into the scope and onto the primary mirror. I'm looking to install some kind of simple, low restriction air filters to the outside of the two fan intakes (see picture). Ideally, I would be able to remove them for cleaning/replacement, by attaching them with Velcro.
Any suggestions?
Doug
djscobel's attachment for post 26118
Posted 08/15/2005 02:25PM #1
Hi Doug
The thin foam furnace filters should work if you use 2 or 3 layers stacked and cut round to fit in the hole snug. You might also install a thin screen or several wires between the fan and mirror box so they don't contact the fan blades. One furnace filter should be enough to make many plenty of small rounds ones. Can be had at Home Depot or Lowes or anyplace with replacement furnace filters.
Hope this helps
Buck
Posted 08/15/2005 05:34PM | Edited 08/15/2005 05:35PM #2
I used Electrostatic filter material for a home heating system and cut it to size. The type that attracts dust particles, mine was blue in color.
Posted 08/15/2005 08:08PM #3
Hi Doug,
I don't know if these will fit or how well it will work but not expensive to try at $3.49. 80mm filter for computer fans at CompGeeks.
Dave
http://www.geeks.com/details.asp?invtid=FFM-80-BLK&cat=FAN
Posted 08/15/2005 11:01PM #4
Has anyone ever thought of using some sort of peel-off, polymerizing liquid screen (like collodion), but optically transparent? It would be applied directly to the mirrors, and then peeled off for your next session. It would be like having new mirrors every time, with little chance for damage. Just a crazy idea...
Jess Tauber
Posted 08/16/2005 02:06AM #5
Thanks for all the ideas, everyone. I think the trick will be getting a balance between filtration and airflow. I'm going to try Bill's idea and use the air conditioner filter material first. I picked up a package today for $2.99. I'll post a picture once I get something rigged up.
Doug
Posted 08/30/2005 12:43PM #6
Here's my solution. I used 1/4" screening cut just a little larger than the openings and pressed in, then some cheap air conditioner filter foam also cut a little oversize and pressed in. Quick and (hopefully not) dirty. I don't know how well it will work, but it ought to keep out any big chunks, and the bugs. Easily removed if it restricts the air flow too much. We'll see how it works at the BFSP.
Doug
djscobel's attachment for post 95395
