Wizard Nebula
Maple veneered plywood?
Started by Grumpy_one, 05/18/2004 07:20PM
Posted 05/18/2004 07:20PM Opening Post
I picked up 3 sheets of 3/4 Maple veneered plywood at Homedepot the other day. I had too, it was only 4.00 a sheet (4x8). It fell of a pallet and has one dented corner. Will this be good wood for a dob? I will more than likely coat it with marine varnish. What, if any, problems will I have? Thanks
Posted 05/18/2004 08:09PM #1
If it is free of voids, then it would work fine I woudl think. Even it it had a few voids that could be easily filled, I would use them. Depending on the joins used for the corners and the edge requirement, you can use any good plywood. You could glue two sheets together fot the 1.5" section of the rocker box and Alt bearings.
I have seen a few made with this type of plywood. Both my scopes are built with this type in fact.
Floyd
fblue's attachment for post 79779
Posted 05/19/2004 12:48AM #2
Dave, another issue I have seen with the Home Depot "special" maple plywood is the thickness of the maple veneer on the top. It chips out very easily so you have to be careful when cutting it.
Good find!
