Hi. I have had this Meade for a few years. I bought it from Bill at Telescope Warehouse 7-8 years ago.
Anyway, there are several things that need addressing and I have a bunch of questions about this hoping for answers from those who might have or have had a similar scope.
What I have already done:
- Crayford Focuser
- Telrad
- Center Dotted Primary
- Complete Collimation (moved primary, secondary, focuser)
- Milk Jug bearings
- Moved Alt bearings down
- Tried polishing bearing surfaces
- Flipped Spider over so access to secondary screws better
Questions I have (adding numbers per request....):
1. Is this Secondary cell put together correctly?
2. Should the secondary be dead center of tube?
3. If Primary isn't centered what do I do?
4. How do I stop primary side to side shift?
5. What is the threaded hole in the center of the primary cell for?
6. Did the weights come with it as new scope?
7. What is the material of this tube called?
8. How much improved contrast will flocking get me?
9. How do I make the ALT/AZ movement smoother (not sticky)?
10. Why did Lemon Pledge make them stiffer? Is there a better item?
11. Did this OTA come with an end cover?
12. How tall should the milk jug bearings be?
13. How is the best way to mount ALT/AZ bearings when I replace them?
14. How do I select the largest WF EP that will work well at F4.7?
15. I have center dotted it 3 times, how do I verify placement?
16. At 1200mm is 300x (4mm Occular) my greatest usable power?
17. Bevel on the primary was black marker and came off, do I care?
18. What is symptom of burnt telrad reticle?
19. Cheshire or Laser?
20. Best deal on green laser?
21. How important is fine focus on a Crayford?
22. Is the metal (not orig plastic) RP focuser worth anything to anyone?
23. How do I cool it down faster?
24. Can tube currents be seen in a star test or is it something else?
Please chime in with anything relevant.
Randy
