james carter
North American Nebula NGC7000
metallic foam- any ATM uses?
Started by yahganlang, 02/16/2010 09:47PM
Posted 02/16/2010 09:47PM Opening Post
http://www.sciencedaily.com/releases/2010/02/100216113603.htm
Jess Tauber
Posted 02/17/2010 11:01PM #1
Open and closed cell aluminum foams are already used in many special applications. I've always thought a baffle tube made from open-celled aluminum foam would be a good way to suppress tube currents in CATs.
http://www.metalfoam.net/commercial.html
Jim McSheehy
Posted 02/18/2010 08:03PM #2
I dunno - light weight is good, but elasticity is bad. For telescope parts, you generally want as much stiffness as possible. I think you'd be better off with the carbon-fiber honeycomb sandwich laminates or other similar things with high stiffness/weight ratios rather than this. And since they are intending it for medical use, I suspect the metallic foam will be very expensive - they are going to be trying to get back the millions they are going to spend getting FDA approval...
Jarad
