The plastic Meade focuser that is on a 114NT is not the smoothest focuser out there (by FAR).
The rack is plastic and the pinion is made of some kind of metal.
Several teeth broke off the rack. Arghh!
Instead of discarding it, I tried an experiment.
1> Filed off all the teeth until I had a smooth surface parallel to the focusing cylinder.
2> Contact cemented a strip of fine Garnett paper for a new 'rack'.
3> Slid a piece of tight-fitting clear plastic tubing over the pinion gear. Extend on both sides, slit the ends lengthwise, and tie off with dental floss to fix in place.
Works like a champ! Smooth as silk. No stepping action.
The hardest part was removing a focusing knob. It was glued in there and impossible to unscrew. Drilled off the screw head, removed the screw with pliers, drilled it out and re-tapped it with an 8-32 tap.
NICE!
I have 2 more focusers to modify. No turning back.
Stu
NICE!
Stu
