When mounting the secondary mirror onto the mounting surface with silicone, do you put a bead around the outside edge of the mounting surface or in the center of the mounting surface? How long should you let it "cure" before installing it into the telescope tube? Is it possible to remove the secondary mirror from the silicone if you decide to change mirrors? Thanks for any help.
Bob
Bob
