Wizard Nebula
Obsidian Optics mirror arrived
Started by AllsWell, 03/29/2006 01:34AM
Posted 03/29/2006 01:34AM Opening Post
I have just received a mirror from Obsidian Optics ... fantastic workmanship from Mark Cowan! At home I will use it in a motorised equatorial mount for imaging, but I would also like to use it in a ultra light weight Dob style mount that can be taken along on Astro-Tourism expeditions. This 14 inch silica mirror weighs about 9 pounds so when I say ultra light weight mount, I really mean it.
I already have Kriege and Berry's Dob book. I also recall an article in S&T from a several few years back, so I need to dig it out. The author had made a very light weight Dob out of aluminium ... but Dob designs move on ...
Can anyone suggest where I can find some of the latest design ideas?
Thanks!
Anthony
Posted 03/29/2006 04:19AM #1
Albert Highe's super-elegant designs: http://www.ultralightscopes.com/
His mirror cell design is also shockingly simple -- pivoting bars on the outside of a triangular frame. (You might also consider a variant where the pivoting bars are instead on the inside of a larger triangular frame, that attaches via collimation bolts right at the tube/box wall.) For travel, I would suggest you first build a removeable mirror cell/box then build a scope around it.
-- William (Saratoga, CA)
p.s. I have a "carry-on" 11" f/4.5 project using four anti-parallel poles and a drumshell UTA -- but you probably don't need something quite that compact.
